anyone got one if there is such a thing? i have no lift so will be changing the line that runs from the front to the back and into the distribution block for the rear on axle stands. i know it goes up and over the fuel tank but im not so sure from there on.. from what i can tell without jacking it up and crawling under with a flashlight is that the line seems to go over the tank then come out somewhere on that side and runs along behind the sill then bends and goes towards the engine bay.
anyone got a diagram or even the length of that section of hard line before bending it to shape? also FWIW i will probably deviate from the stock routing at the fuel tank and run the line around either on the outside or the inside where the tank clears the propshaft and then into the distribution block. dropping fuel tanks to replace brake lines FTMFL.
