Let me know what control arm bushings to go with. I hear good things about Treehouse Racing, but are there any others I should consider? Do the THR ones really make enough of a difference?
Need control arm bushings...what to go with?
THR will give you too much caster on an ix. I already rub the fronts of the fender liners with M3 offset bushings, and THR pushes the wheels forward even more. plus, there's really no need for soild mounts on a street car, all you're really doing is wearing out your ball joints faster.
I would go with solid centered or M3 offset.Comment
So you would go with M3 offset or either, b/c you have the M3s? What is the major difference going to be?Originally posted by nandoTHR will give you too much caster on an ix. I already rub the fronts of the fender liners with M3 offset bushings, and THR pushes the wheels forward even more. plus, there's really no need for soild mounts on a street car, all you're really doing is wearing out your ball joints faster.
I would go with solid centered or M3 offset.Grant Wescott
1991 Sterling Silver 325iX stock (daily driver)
1991 Black 325i stock (parts)
"Eine Wurst, drei Größe"
ThanksOriginally posted by kencopperwheatOE Sachs bushings = $24/pairOriginally posted by GrantGood handling DDOriginally posted by kencopperwheatWhat's your objective for the car?
OE M3 Offset = $76/pairGrant Wescott
Firstly, you're nuts if you think BavAuto is the best online dealer. I've dealt with many (including BavAuto), and BMA is definitely the best, ESPECIALLY when it comes to customer service (not to mention they'll pricematch anyone).Originally posted by Kilomphbavauto which is by far the best online dealer has them for $54.95.
I don't work for them, but because they're such a good vendor I try to help them out.
Did the E30 M3 ever come with non off-sets? For a daily driver would you get off-set or non?
Secondly, you're going to want to look closer at the price of BavAutos bushings. They're $54.95 EACH = $109.90 per pair. Blackforest has them for $69 per PAIR (37% cheaper).
No, the M3 always had offset ones.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
They're an advertizer for this site... so you'll see their banner at the top every once in a while.
Patrick is a great guy to deal with.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
keep in mind the ix has it's own bushings, it doesn't use the same ones from other E30s. I never looked at prices but I'd assume they are more than $24 a pair.Originally posted by kencopperwheatOE Sachs bushings = $24/pairOriginally posted by GrantGood handling DDOriginally posted by kencopperwheatWhat's your objective for the car?
OE M3 Offset = $76/pairComment
