OE E30 M3 Front Rotors
  • g22
    • 274
    Anyone have a good place to find deals on OE e30 M3 front rotors? I've got a e30M3 five lug swap and I keep cracking aftermarket rotors on track. A big E30M3 guy suggested I run OE rotors. He's never had a terminal crack on OE rotors. The dealer wants an arm and a leg for them. Thanks
  • Rob@UUC
    • Nov 2007
    • 420
    What are you using for pads?
    - Rob Levinson
    UUC
    - Rob Levinson * UUC Motorwerks * 678-679-5360 * http://www.uucmotorwerks.com * rob@shortshifter.com
    Phone calls preferred. Email second. No PMs, that's why I have real email. :mrgreen:
    BIG BRAKE KIT HEADQUARTERS!
    Your source for E30 Ultimate Shifters, SwayBars, Brake parts/Big Brake Kits, and much more!
    First ever LED headlight conversion - [ CLICK HERE ]
    • g22
      • 274
      Hey Rob, I'm using HT-10's.
      • FredK
        • 14763
        I think you posted this same topic on s14.net, which is down at the moment.
        In any case, I really don't know, because I drive like an old woman.
        But to help other people reading this thread, you said you were using Zimmerman blank rotors, right? Are you running any ducting? Or are you using stock backing plates?
        • g22
          • 274
          Actually, it was e30tech where I posted. I wonder if others are having this problem.
          I have the ducting that takes the air from the front directly into the wheel hub. I have cracked a brand new Zimmer and an SP performance. I just bought some really expensive OE rotors so we'll see how that goes...
          • FredK
            • 14763
            Have you rebuilt the brake calipers? Are you running brass bushings? This might be a hydraulic issue where the calipers are lightly dragging.
            • g22
              • 274
              Yes, rebuilt them about 9 months ago. Interesting you said that. I re-rebuilt them on this past sunday. I'm running the brass bushings at all four corners.
