Polyurethane bushing owners, get in here!
  • Sagaris
    • Sep 2009
    • 2243
    I am torn between rubber suspension bushings and polyurethane. My concern is noise. I do not want squeaky bushings and suspension noises. Do you have problems with the bushings being squeaky , is there a surefire way to prevent this or should I just get rubber bushings and be done with it.
    34
    I have polyurethane bushings, no squeaks whatsoever
    50.00%
    17
    I have polyurethane bushings and they squeak
    17.65%
    6
    I have polyurethane bushings, they squeak but I keep them quiet with some sort of lube
    5.88%
    2
    JUST GET THE RUBBER BUSHINGS YOU SISSY!
    26.47%
    9
  • NC325iC
    • Mar 2004
    • 6565
    squeek over speed bumps and im sure at other times but i only hear them over speed bumps
    • shiboujin
      • Feb 2006
      • 2791
      Get poly if you need it. If the car doesn't see the track that often, you're fine with rubber. 75D poly is good for trailing arms. Less deflection.
      Btw "Self lubricating" is a physical impossibility. It's just a low friction surface.
      • BimmerTim
        • Oct 2007
        • 613
        Mine squeak, but not that much. Either way, I love them.
        1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
        2008 VW Rabbit
        1991 Audi 200 20vtq Wagon
        • e30polak
          • 6136
          Great suspension upgrade, really tighten up the responsiveness of the suspension. I love all my poly bushings! :-D
          INSTAGRAM: @UNDR8D_EMPIRE
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            I have poly control arm bushings and they do not squeak, but I put anti-seize on them when I installed them
            -Andy
            • 5KWattson
              • Apr 2009
              • 809
              I'm looking into gettin poly sub frame and trailing arm bushings anyone have some and what's to be expected is it worth the money? For spirited street and light track use
              "God created turbo lag to give V8's a chance" Taylor D.
              • cobraken
                • Oct 2004
                • 674
                Through my experience with poly unless its a race car go rubber.
                Poly makes the ride much more rough. If you put a good set of shocks/springs and sway bars the car is plenty of fun and its still very streetable.
                I have a car with all poly and just about everything in the catalog on it. Its not any fun to drive as a daily.
                Just my opinion.
                Randall Racing and Engineering
                Acworth, Georgia, 30101
                http://www.facebook.com/RandallRacingandEngineering
                • deutschman
                  • May 2008
                  • 5958
                  just lube them up right and you will have no problems at all.
                    • 34847
                    I've had poly bushings for almost 8 years and I've never heard a squeak from any of them.
                    I don't know how they'd squeak, none of them have moving parts. the TABs rotate around a steel tube, the bushings themselves don't move anywhere.
                    I also noticed virtually zero increase in NVH.
                    • Naplm00
                      • Nov 2008
                      • 1573
                      i have poly rear subframes, and lubed the living shit out of them, ive never heard anything
                      88 325ic ~~~> Rusty and ugly
                      85 E ~~~> RIP
                      • e30s50dan
                        • Nov 2008
                        • 2076
                        Good to hear. Just ordered powerflex bushings. Going to start with rear. Get the PITA over first
                        NASA
                        BMWCCA member
                        PCA member 25yrs
                        1991 318IS slick top
                        1997 M3 sedan
                        2001 325CI DD
                        “whoever turns the wheel the least, wins"
