I'll confirm Corroda rotors fit(have to machine out the center bore). And there is a set of cheap 4-piston calipers that will fit with a simple Bracket
*ahem*
:tsk:
there are no cheap 4-pistons.... its all a lie! ;) :P You got my hopes up for NOTHING :D
If somebody does fine some Dirt cheap 4-piston calipers I want to know. I'd look into the 750il front calipers, E28 guys find them all the time, a rotor that fits is all that is needed.
They have prices. As soon as I work the electrical gremlins out of my car I'm going to be working on milling out some mounting hats for a front kit. I have a strange design for the rear that may let us keep our ebrake... We'll see.
I've heard IE just uses Corvette calipers for there kit. You could buy the rotors just from them, and get the calipers cheap off ebay.
If you have a junkyard with cheap prices, just go and get some 4-lug rotors and start mixing and matching with calipers till you find a match. Heck if it's a pull apart yard you don't even have to buy them, pull them off and start putting them on e30's. :twisted:
But the Wilwood calipers are cheap, and light, with parts readily available for good prices.
cool, keep us updated on the custom 4 piston caliper deal.
I have a full set of Porsche 993 brembo calipers sitting in my room crying to be used. But i dont know where to begin.
haha- start by finding a wheel with a 40mm offset and a 20mm spacer, cuz you're going to need it to get clearance on those calipers!... maybe not that extreme, but yeah...
