cheapest big brake kit?
  • bmwdude
    • 268
    Can anyone steer me to the cheapest big brake kit out there?
    Thanks!
  • Jordan
    • 12913
    IE
    https://mtechniqueabs.com/
    • Skafrog
      • 1732
      I heard through the grapevine that Corrado front brakes will work on our cars with modification.
      Check that out,
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
      • bmwdude
        • 268
        Check that out,
        Yes, I have heard that too....also heard earlier 4 bolt Chrysler stuff will fit too. Question is who has had the time out there to mix and match nice large rotors with 2-4 piston calipers etc, and make it all work. The IE kit sounds good with the Vette calipers and 310mm rotor size. $1250 is alright, but I have to deal with a lousy exchange rate (as you US guys are now getting a taste of it too with the Euro). I was just kind of hoping for a SLIGHTLY cheaper alternative. I just don't have the time and/or a CNC machine to experiment with parts from the junkyard, otherwise I would.
        • DanGillan
          • Mar 2004
          • 4061
          check out movit
          Dan
          • royalflush313
            • Mar 2004
            • 2070
            check out RPI Equipped in Vancouver, BC. They have their bbk using wilwood calipers.
            ~ Go Canucks Go! ~
            • rs4pro3
              • 5808
              :Edit:
              85 325e 2.7 ITB'd stroker
              • bmwdude
                • 268
                These guys seem to have the lowest prices. Thank guy!
                • bmwdude
                  • 268
                  Originally posted by rs4pro3
                  I'll confirm Corroda rotors fit(have to machine out the center bore). And there is a set of cheap 4-piston calipers that will fit with a simple Bracket
                  Sounds good!!!.....and I anxiously await!!!!
                  • Streetspec_iS
                    • 1622
                    I heard through the grapevine that Corrado front brakes will work on our cars with modification.,
                    anything will fit with modification.
                    sigpicM42 Brigade ... Throwing craze in the 318
                    • Rob
                      • 8166
                      quality pads, fluid, lines, and bleeding are truly the cheapest brake upgrade. doesnt really help in show points though
                      BEERTECH
                      • Mtriple
                        • 3139
                        I ordered the last kit on hand at RPI last Wednesday. Warren said that they would consider doing a run again if there was enough interest. They have to order a minimum of 10 from their fabricator so I'm not sure what he is looking for in terms of a "minimum" amount of interest...
                        Originally posted by Simon S
                        • bmwm3n528
                          • 3654
                          You make me sick :D
                          That's going to be such a sick e30.
                          Trevor Ely
                          '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                          '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                          • JPbmw
                            • 466
                            i thought all this was still a secret :?
                            '86 325
                            • mikeedler
                              • 6707
                              well, dont hold out, what is it and what do we need?
