Sooo.. i go to fix my ABS..
  • BS87
    • 1606
    Well, i figured out my ABS wasn't working on the front wheels, because 1 sensor was unplugged, and 1 was missing. I got some sensors off a junkyard E30, and i jacked mine up to throw them on.
    What the fuck? There's no slot for the ABS sensor. However, right where there should be, there is a flat, raised surface in the exact shape of the ABS sensor flange thing.
    This makes no sense, the only possible thing i could think of is that the car was in a major front end collision requiring the replacement of both front strut tubes.
    Can anyone tell me where the part numbers are on the housing so i can look them up (Or any identifying marks).
  • kowalski
    • Jan 2005
    • 1791
    no idea, but the guy prolly did his own repairs and pulled them off an e30 without abs.
    • UNHCLL
      • 8790
      you only have 1 abs sensor per end of the car.
      drivers front, passenger rear.
      Below the radar...
      • kowalski
        • Jan 2005
        • 1791
        no, you have an abs sensore on each brake, you have 1 brake sensor on each end of the car, those tell you when your pads where out, they're usless.
        • UNHCLL
          • 8790
          no you dont.
          2 abs sensors per car.
          as stated above.
          E30's are archaic automobiles. one per end, not like new cars with 4 independent abs sensors.
          and you also only have 2 brake pad wear sensors.
          Below the radar...
          • boom-monkey
            • 1104
            Are you absolutely sure?
            On the e30's I've worked on with ABS there has been a sensor on both sides up front, and the ETK comes up with both a left and right side sensor.
            That's for the front at least, I've never had to deal with the rear ABS, nor am I even sure if e30's have rear ABS.
            • UNHCLL
              • 8790
              No, I lied.
              he was right, i was wrong.
              i got my models confused.
              Below the radar...
              • kowalski
                • Jan 2005
                • 1791
                  • 34839
                  wow.. my car has them on all 4 wheels. are you sure about that?
                  edit: i'm slow ;)
                  • UNHCLL
                    • 8790
                    edit: i'm slow ;)
                    its an iX.
                    who cares...... :P
                    Below the radar...
                    • BS87
                      • 1606
                      It's almost like it's an aftermarket piece... Because the raised portion is right where the ABS sensors go, just flat with no holes... the pre-ABS cars don't have the raised portion, i'm pretty sure. I'll try and take a picture sometime this week.
                      • Dave
                        E30 RAT
                        • 11675
                        You still have this problem?
                        I just pulled my strut housings off and they have the openings for the sensors.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
