BREMBO 4 piston from evo 9 to E30
  • panose30
    • Nov 2009
    • 105
    hi,,i have made a big brake upgrade to my e30..brembo 4 piston red calipers and 325mm drilled brembo discs ,racing pads and racing lines from mitsubishi EVO 9 mr,to put them i made custom bruckets, redrilled the disc to make them 4 lug,and 1cm aluminium spacers with racing sparco bolts,,the brake now is like train ,total cost 500 euro because the person who put them on is my friend,,enjoy the photos.ask me any details if u have
    behind the 17s they still look huge
    [IMG][/IMG]
    on the air
    [IMG][/IMG]
    [IMG][/IMG]
  • panose30
    • Nov 2009
    • 105
    and anothe 2 photos
    [IMG][/IMG]
    the original on the left and the brembo on the right,,the different is huge
    [IMG][/IMG]
    • Wishno87
      • 6025
      OMG do want
      • E30_fiend
        • Apr 2006
        • 7348
        jesus man, you need to post a write up
        • Hey-U
          • Mar 2008
          • 560
          That looks really good, would like to hear more.
          • Wh33lhop
            • 11705
            Brown-bos? I'm not sure how well those actually held up to track use on an evo, but they're an upgrade for an E30 for sure. How's the brake balance?
            paint sucks
            • mcr_driver
              • 4491
              more info indeed please
              • panose30
                • Nov 2009
                • 105
                the brake now is perfect,,stop the car is seconds..like a train..and the show of the red calipers and the monster discs is all the money..i push them hard one time and i shit on me,,the brake force is brutal..
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  Wow!! I want a set. Do you have some details on how you made it work? Maybe a writeup?
                  • SickE30
                    • 769
                    Did you have the flu or something? Just kidding, good work man. A writeup would be great!
                    • panose30
                      • Nov 2009
                      • 105
                      first job was to make custom made brackets,,the most difficult work(i dont know exactly the mm of the brucket),,then i cut the original aluminium plate behind the original brakes to put the biggers discs,,then the discs get redrilled to make them 4 lug,,then another problem came up and was that the biggers calipers hit the rims,,to fix that i put aluminium 1 cm spacer with racing sparco bolts..them another problem came up..the rims inside center circle was smaller thn the spacer so i redrilled the rims and make the circle bigger.then another problem came up..the disc hit the bolts that hold the entire system(i dont know the translaton lol)so i put differnet bolts which are smaller 1 mm..then another problem came up..the brake oil pump didnt work well because of those huge calipers so i put 325i new one from the dealer,,as you can see a lot of work and problems came up,,its difficulty job and i was getting very down when problems came up one by one,,but the final result is perfect now
                      thanks god(sorry about my english)
                      • 2002maniac
                        • 4260
                        Nice setup! What size are the pistons? How's the F/R bias?
                        • ChaseN
                          • 709
                          ...the brake now is like train...
                          Doesn't a train take like a half mile to stop? (sorry, had to... :D)
                          1991 318iS
                          1992 911
                          2006 330i 6-Spd ZSP people hauler
                          Gone:
                          1989 M3 S50B32, 6-Spd
                          1990 325ix 5-Spd
                          • mayhem
                            • Feb 2007
                            • 33
                            Brown-bos indeed. On my Evo 8 they turned brown first day at the track and black by the second day. It's a heavy car with lots of HP, so the key is using every brake cooling trick you can...ducting, high temp fluid, right mix of pad compounds an adjusting your braking technique. Not a good feeling when the pedal hits the floor and the brakes are gone.
                            I'd really like to see some pictures of the mounts.
                            • dnova89
                              • Aug 2009
                              • 851
                              Wow, nice work. I'm definitely way too lazy to ever do anything like that.
                              -Darius (aka DiscoDoughnuts on other forums)
                              dude man bro...
