I.E. rtab bushing orientation..
  • X_WizarD_X
    • Jul 2005
    • 99
    About to install some IE rtabs. They are thicker on one end then the other.
    Does the thicker end go towards the outside (wheel side) or inside (towards diff.)? Replacing all 4 with toe/camber correction kit..
    Thanks,
    Dan
    The Keystone Killers: for the Commonwealth!
    Member #18 of M42Club.com
    1991 318is Diamantschwarz Black
    1992 850i Calypso Red
  • dinanm3atl
    • Feb 2007
    • 7305
    Ireland has close to ZERO post sale support in terms of this part(or any of their parts really). I JUST did them this weekend though. I had a stock E30 to look at as well as a car with AKG. Both the stock and AKGs have the larger side towards the outside of the car on the outer holes of the trailing arms and the fat side goes towards the inside of the car on the inner trailing arm holes.
    So it is Thick Skinny Skinny Thick.
    Also. You may have to trim/sand both sides. I JUST installed these and lawdy it was a PAIN IN THE ASS. They are oversized and would not physically install because if you got one of the bushings lines up the other one was the thickness of the bracket off... I took them down... Press them together and again... SAME thing. Finally decided to trim them and sand the ends and it first a lot better. Slides right in. Tighten down and fits perfect.
    Thanks Ireland... :shifty
    • Dagamus(NM)
      • 618
      Yup the thin parts go to the center of the A each side.
      And yes they are a bitch to fit. You might want to use a lot of lube and a pry bar to slightly open the tabs. Don't worry they will go back when you torque down the bolts.
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
      • dinanm3atl
        • Feb 2007
        • 7305
        We tried that first and used a lot of lube... it is hard to get anything in there to pry against and trimming them slightly worked a LOT better and once torqued down it was perfect.
        • AndrewBird
          The Mad Scientist
          • 11898
          That's what she said.
          • dinanm3atl
            • Feb 2007
            • 7305
            DAMNIT! I saw that all the time and totally missed the chance! Nice one.
