So I had to R&R the subframe, trailing arms and associated parts. I disconnected at the e-brake handle. Pulled it all out. Before that I marked with white out the bolt and threads. Get it all back together. Well the brake disc was not installed. Pull the lines through. Tighten them to where they were previous installed...
Then like a retard I decide to pull on the e-brake handle. It was super loose and go.. oops. There is no brake disc and thus no 'drum' for the brakes. It was very difficult to get the brake disc back on and even with the e-brake handle depressed it is very hard and almost impossible to get them spinning them by hand at the brake disc.
Put it in gear and just slowly let the clutch out and it is fine. Do I need to adjust this? How to do that? Once I get it back on the ground and driving it will auto adjust(I know some cars when you put it in reverse and activate/de-activate the e-brake it pulls it into adjustment.
Or anything else to check/adjust? Can't really take it for a spin and the e-brake worked perfectly before. Shoes were in tip top shape. Waiting on my suspension and front brakes before it can be driven.
