suspension & brake system rebuild
  • hellakush
    • 254
    i'm going to start getting my e30 headed in teh right direction and would appreciate some help in quality replacement parts and a parts list.
    let's start off right:
    1 - a list of all needed bushings, balljoints, etc. for a complete suspension rebuilt would be appreciated.
    2 - it seems the rubber breaks lines are rotting in a bad way and i figured i might as well go steel braided. i've seen a price range from $80-$180 but have never heard of any of the brands. do you guys have any suggestions on where to shop for quality lines at a decent price?
    3 - i will be ordering new wheel bearings/hubs as well and info on the best place to pick up quality fairly priced parts would be appreciated as i have found prices ranging from $70-$120.
    4 - looking for a place that sells quality fair priced rotors too.
    5 - i plan on getting some full blown coilovers asap and was curious what brand you recommend as being the best for height control and handling. at ecstuning.com, they have a core charge for the spindle housings (and are cheaper after that) and the others don't which leave me scratching my head. why don't gc & kw need these? and if you say you get what you pay for as i'm looking to save $200+ on the fk brand over the others, think again as i have owned that brand and it is a company that puts out quality products. please remember that i am looking for the set-up that goes the lowest and handles the best at that height. as of now i am looking at fk, kw, & gc but if you have any others or input on what i am asking, let me know.
    sorry for all the questions and the semi-long read. any help will be greatly appreciated.
    on a side note, i might be interested in a 5-lug swap asap if you have one for the right price but you would need to let me know before i waste money on the rebuild parts.
    or since i want to do a steering rack upgrade and engine swap down the line, should i consider just going a big brake upgrade up front so i don't waste money on something i will be taking off.
    I'd rather bag your mom than my car :D
  • drumad
    • Aug 2009
    • 1700
    I hope I dont screw up here for all bushings/wear parts
    front:
    cabs
    tie rod end bushing
    control arm ball joint bushings (might as well get a fresh lemforder set)
    sway bar links
    sway bar bushing
    bumpstop
    mounts
    rear:
    trailing arm bushings
    subframe bushings
    diff bushing
    mounts
    sway bar link
    misc:
    guibo
    center support bearing
    transmission/shift bushings
    motor mounts
    tranny mounts
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • hellakush
      • 254
      thanks you sir :D
      • payney8
        • Jun 2007
        • 899
        that looks the go also with the stainless lines. Just have a good look at the weave and quality of the rubber
        • firemanory
          • Dec 2008
          • 488
          Are you looking at OEM or Poly for rubbery bits. If Poly, consider AKG. Lots of guys run them and they are a great small operation catering to the BMW enthusiast. I would think SS brake lines would all be about the same, but I may be wrong. I remember when I got mine there lots of different companies selling the same brand, some as their private label stuff and some as just that brand. I am not sure if I got mine from Pelican Parts or RMEuropean, but check around to see what is out there.
          Good Luck
          • hellakush
            • 254
            Good Luck
            done did it already and yes, i did do stainless steel lines. bought almost everything through bavarian motorsports with the exception of the softest available akg subframe mounts.
