Stopping brake squeel?
  • Kruzen
    • Mar 2004
    • 5603
    I redid my rotors/brakes about 10k miles ago.. sensors too.. (senosors works great for about 1-1.5k miles and then they tripped :-/
    Since i did them theyve still squeeked.. it didn't used to be too bad and i thought it would go away.. but its just gotten worse and worse (and some what balanced out to the same annoyance of squeeking the last5k miles.. )
    What could be causing the squeek? DrkWng just did his rotors and brakes and isn't having a squeeking problem at all..
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • hamann318is
    • 3382
    Squeeking is a vibration between the pad and the caliper, it's happening so rapidly that it sounds like a squeek. You can goto pepboys/autozone/etc. and grab a anti-squeel kit which is usually a gel or rubber like pad that goes behind the pad.
    The BMW 318 is back. With a vengeance.
    • Kruzen
      • Mar 2004
      • 5603
      would there be any issues if I just took like a rubber washer and put it behind it?
      • Skafrog
        • 1732
        go buy some anti-squeal spray. Dont use a rubber washer.
        NASA MidSouth TT Director / GTS2 #018
        Mods: Coastal PS Fluid, 10w40 Oil
        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • Kruzen
          • Mar 2004
          • 5603
          :twisted: ok heh.
          • hamann318is
            • 3382
            Yeah, don't use a washer.
            • DarkWing6
              • Apr 2004
              • 7144
              Re: Stopping brake squeel?
              Is it really that hard to add the a and the i in my name? :D
              Out of curiosity what pads and rotors are you running?
              • Fred
                • 659
                You can also use an anti-squeal on the pad surface in addition to the backing plate. It's a black liquid that you soak into the pad for a few minutes and it helps prevent squealing. We get ours from the Mercedes dealer (it's called Stop Squeal, or something like that) but I think local auto stores sell it too.
                If you didn't bed the pads/rotors correctly, they can also make noise later on.
                '86 325 2.8i stroker - Arctic Blue
                '11 328i Sports Wagon - LeMans Blue
                Strictly Eta
                • Kruzen
                  • Mar 2004
                  • 5603
                  Ate rotors and Pagid pads.
                  and sorry, i thought your name lacked them.. lol.. tard is me.
                  • DarkWing6
                    • Apr 2004
                    • 7144
                    Try to see if it is coming from all 4 or just 1 or 2. If it is coming from all 4 do the anti squeel stuff, but if it is only 1 or 2 try reinstalling them and see if it is how they were sitting.
                    • Kruzen
                      • Mar 2004
                      • 5603
                      Mmmk..
                      Also, i over heard someone say that if your pad sensors have been broken it can cause it too.. Is there any merit to that? anyone?
                      • Fred
                        • 659
                        Pad sensors don't cause squeaking.
                        Strictly Eta
