New Front Pads - Brake lining light constantly stays on
  • NickL
    • 562
    Alright, so my brake lining light started to flash when braking so I decided to replace the front pads on the car.
    After the installation, along with a brand new sensor, when I started/drove the car the light just stayed constantly on.
    Any ideas? Would I need to reset my battery possibly? Im almost positive I installed the sensor correctly.
    Thanks a lot.
    -Nick
    1987 325is - S52
    Check the rear brakes & sensor.
    • Rob@UUC
      • Nov 2007
      • 420
      Even if all the sensors are good, it may take a few key cycles to reset the light.
      If you literally just did the service a couple of days ago, it may not have been enough key cycles. Simply turn the key off and on (all dash lights on, but not starting the car) about 10 times, see if that does the trick.
      - Rob Levinson * UUC Motorwerks * 678-679-5360 * http://www.uucmotorwerks.com * rob@shortshifter.com
      Phone calls preferred. Email second. No PMs, that's why I have real email. :mrgreen:
      BIG BRAKE KIT HEADQUARTERS!
      Your source for E30 Ultimate Shifters, SwayBars, Brake parts/Big Brake Kits, and much more!
      First ever LED headlight conversion - [ CLICK HERE ]
        • 34839
        E30 brake lining lights don't have anything to do with key cycles and do not need to be reset - it's just a ground to the brake lining light from the two sensors.
        if it's on, the sensors are either broken or not connected properly. I got tired of the stupid system, since I always had false lights with new pads, and finally removed the bulb and sensors. if you look at your brakes once in a while you really don't need it.
        • Dirtbleed
          • 495
          I removed the bulb and the sensors as well. Shit dont work that well after 20 years old.
          • metalsoul
            • 871
            There may be no direct corelation but check your ABS brake sensors too, they will trigger the brake lining light as well
            BUY YOUR KLUB VINTAGE WINDOW DECALS!
            http://www.r3vlimited.com/board/showthread.php?t=265552
            Klub Vintage - Classic and specialty car builds and restorations
            http://www.klubvintage.com
            Located in Lambertville NJ
