trailing arm jig.
  • Mike The Bavarian
    • 488
    trailing arm jig.
    Going to be making a jig to reinforce trailing arms this week. I'm going to pick up a spare set of arms at the junk yard and see how it comes out. I'll post picks when all this happens!
    And the point of this is?
    • Mike The Bavarian
      • 488
      .........to reinforce the trailing arms?
        • 34839
        m-coupe style? be careful, if you put it in the wrong place it can interfere with other underside bits of the car. a dude did this on an E30 M3, put them too high and they hit the gas filler tube, so he had to cut them off (see "minor rust repair" thread)
        • Mike The Bavarian
          • 488
          I'm adding a brace where the m-coupe has it and then I'm adding a brace where the hub connects to the trailing arm to prevent flexing so camber and toe isn't affected as much.
