New control arms not fitting
  • SwiftE30
    • Jun 2010
    • 998
    I bought new lemfoerder control arms for my 89' 325i vert and it seems like i have tried everything possible to get these to fit into the strut with zero luck. I've tried anti-seizure, blocking, and jacking and nothing seems to make that stud budge whatsoever.
    This is the last thing i need to do before i start my s52 swap and i am extremely frustrated. Any help would be great.
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
    • 37833
    Are you putting them in the right hole (not the smaller tierod hole)?
    Check the part numbers, make sure you got the right parts.
    Grover Beach, California
    BimmerHeads.com
    • SwiftE30
      • Jun 2010
      • 998
      yeah they're the right parts and they are going in the right hole. Im going to try and use something to heat the strut hole up a little bit and see if that will help at all.
      • redhatpat
        • Aug 2005
        • 656
        I sense disaster.
        You shouldn't have to force these parts together, something's wrong. Take a minute to think about it before you fuck up something expensive.
        • iignite
          • 125
          i dont understand whats the issue, did you bolt up everything else right? making sure the lollipops are in the right orientation? You shouldnt have to heat anything up
          • SwiftE30
            • Jun 2010
            • 998
            yeah everything is lined up fine. and all other new parts are bolting right up. lollipops were installed correctly and tie rods fit fine. I used a caliper to measure the size of old control arm stud to the new one and the old one is actually a tiny bit bigger than the new one. Plus the old one was a bitch to get out, so i just assumed it would be an even bigger hassle getting the new ones back in. I only need to get a few more millimeters into the strut hole and then i think threading it with the nut will suck the rest of it up.
            • McGyver
              • 4636
              DONT USE HEAT! you are doing it wrong. this is how they line up. tie rods use the smaller hole.
              • SwiftE30
                • Jun 2010
                • 998
                I got it. THanks!
