Just making sure. I got a set of front powerslot corrado g60 rotors for this kit. I am going to need to shave the inside hub of the rotor 1mm for them to fit on the e30 hub right?
RX7 caliper and bracket Roll Call
Originally posted by Tree18is View PostBasically I want to know who is running the brakes and what wheels you are using. I tried to install mine today with 16" style 5's and there is no way that wheel combo will fit the brakes. Neither will the BBS RS in 16"
Originally posted by graphikg View PostI was thinking of painting the calipers... Can you recommend a good paint. I wanted to do purple but too hard to find. I guess I have to do black or red as usual
Also, do you guys know if I can not run 4 lugged Corrodo Calipers? I'm doing a 5 lug swap, and I would still love to rune an rx7 BBK, but don't exactly know if that's possible. Anyone come across a 5 lug variant that might work..?
My vote is in for sticky. Best informative thread I've read this year
I am very very sorry to say... But these calipers DO NOT fit the TR Motorsport C1 15x8 wheel without issue. Ive ground the hell out of brand new calipers and am still having trouble. They absolutely need spacers of at least 5mm. I am having a lot of trouble fitting these wheels onto the calipers. It is quite frustrating. I am even thinking that I need a 10mm hubcentric spacer and even needing to buy some studs.
Originally posted by graphikg View PostYou must have the FC turbo caliper version. I think I have the FD calipers which do not have the nub... I think theyre a little different.
See...no nub - the design is quite different.OBD1 M54/M52TU swap as a M50b25
They fit BBS RC090s (e39 style 5s) with 22mm spacers. If your going to run the thin spacer behind the rotor then 20mm spacers should do the trick.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
