Inner rear brake line installation with subframe in?
  • Night Wolf
    • 85
    I am currently replacing my rear wheel bearings, other then a few odds and ends, the rear subframe is ready to be put back together and installed.
    I ordered a set of stainless brake lines from UUC, but they are on back order. I wanted to get them in before the subframe goes back up.
    If I remove the old lines and install the subframe, so the only thing left is to install the new lines, would that be a PITA? Would it be worth it to complete other projects on the car (plenty) until the brake lines arive or can I get the subframe and all the components out of the way and back under the car?
    ~Rick | 1990 325iC ~Noelle - Her build/cleanup thread http://r3vlimited.com/board/showthread.php?t=179507
    Remove the two soft lines while the subframe is out. That is the hard part. It isn't too difficult to install the new lines with the subframe in place.
    • JTapper
      • Sep 2009
      • 847
      I had just the opposite problem. I got them out with the subframe in but couldn't get them back in. I installed the soft lines from the body BEFORE installing the subframe. It was cake.
      Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
