Brake Pads - Which would be best for my application?
  • hamann318is
    • 3382
    My rotors have finally warps, and my pads are loosing bite. I'm 100% this is the factory system, so I'm replacing rotors and pads. For the rotors, I'm looking at ATE Slotted rotors for the front and OE (Brembo) rotors for the rear. I'm not too sure on what pad I should run. I intend on autoxing a few more times this season, and I do mountain runs on occasion (heavy brake usage). What pad would be best for this type of application?
    The BMW 318 is back. With a vengeance.
  • Jand3rson
    • 37587
    I would suggest EBC Greenstuff, they are great pads and fairly low dust. I'll be getting the same.
    • bimmerphile
      • 3495
      I'm running Pagid Reds and Hawke Race pads.
      Great pads after they get warmed up....except for the squeal.
      But hey, when I want to stop.... ;)
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        axxis ultimates.
        • Mike 91 318ic
          • Jun 2004
          • 429
          My dealer installed oem brakes are far better than the after market brakes that were on there before... Great stopping, little dust and totally quiet.
          M
          • Mot
            45 toting redneck
            • 4018
            ebc green stuffs served me quite well.
            • hamann318is
              • 3382
              M
              I found out from Patrick those are Pagid pads. I was considering those as well.
              What do you guys like about the pads you are using?
                • 34847
                I'm using Pagid with ATE slotted rotors. these things last forever. I have 25,000 miles on them and they aren't even halfway through the pad yet.
                they are not dust free, but they work well. I've also autocrossed with them, dropped the anchor at 120 a couple times, stopped on sheets of ice with them, etc. etc. I actually replaced my brake fluid before I replaced the pads!
