changing control arm??
  • nicky51
    • Jan 2010
    • 158
    Just a quick question. Do i need special tools to change my control arm? how hard is it and can i do it with a jack... Thanks..
  • LivingLegend06
    • Dec 2006
    • 1604
    Control arms are a pain to get out of the control arm bushings. Make sure you have grease and a table vise and some upper body strength to get them on/off.
    • caliGreen
      • 195
      taking the control arm is easy just a couple of bolts.. takeing the bushing out and replacing it is a bitch unless you have a press
      • nicky51
        • Jan 2010
        • 158
        reply
        But since im getting a new control arm doesnt it come with the bushings on it?
        • nicky51
          • Jan 2010
          • 158
          reply
          But since im getting a new control arm doesnt it come with the bushings on it? So i shouldnt have to deal with it or am i wrong... Thanks..
            Nope
            • FredK
              • 14763
              If you decide to do the job, please exercise caution and support the car with jack stands, not just a jack.
              • caliGreen
                • 195
                indeed safty first.
                yeah you just need to replace it.. so it will pretty easy. not as easy as oil change but do able
                • nicky51
                  • Jan 2010
                  • 158
                  reply
                  Ok thanks for the info guys. i will definitely use stands.
                  • HarryPotter
                    • Jan 2010
                    • 3642
                    Pretty sure new control arms come with fresh ball joints pressed in just not the CAB. Rent a 3 jaw puller from autozone or discount makes getting the CAB off a piece of cake.
                    John F. Kennedy
