Hey guys I have a weird issue with my e30. I turn the car on I get no lights on the cluster and everything seems fine. I hit the gas and go about 5-10mph then hit the brakes softly and the abs kicks in. It kicks in for like 5 seconds then the abs light turns on. Any idea what is going on? Or where I should start looking 1st? Thanks for your help.
Abs turns on at 5mph.
Tags: None
OK thanks. I assume its the sensor behind the hub that comes out with a allen key. And the teethed ring is also on the back of the hub?Comment
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
I had the same issue about 8 years ago. Either the ABS light would be on and it wouldn't work, or the ABS would kick in at 5mph. It turned out my pulse wheel on one of the rear wheels was coroded and caused the sensor to give bad readings. The fix for the time being was to remove the ABS relay.-Brandon
'86 325es S50
'12 VW GTI Autobahn DSG
'03 540i M-Sport (sold)
'08 Jeep SRT-8 (sold)
For sale:
S50 TMS chip for SchricksComment
If you remove the relay, you will lose ABS and your brakes will lock up in the rain, so be careful!
My ABS is malfunctioning also, did the diagnostic of pulling one sensor at a time, replaced the relays with known good ones, and the light is still on all the time. Got a good scare in the rain last week, fronts locked up, had to pump them like crazy because some id10t in Boca decided to cut in front of me just as the light was turning yellow and slammed on his brakes :(
I have some spare sensors if you ever make it out to the shop ;)Comment
this happened to me over the weekend. pulled off the passenger side front wheel to find that something cut my ABS sensor wire in half. Did the repair and its works like a charm.1991 318i Sedan
2005 X5 3.0i Sport
2010 328i M-Sport Touring
