ireland engineering sleeves too big.
  • Faviolosky
    • Nov 2008
    • 154
    so i bought ireland engineering subframe poly mounts bushings and i finished tightened it and to my surprise the subframe could still move up and down on the mount.
    there are about 4 or 5 threads to the bolt so i know that its not undertightened.
    WTF how can i fix this
    is there a sleeve or spacer that is supposed to go there or what.
    • 37829
    Did you put the OEM washer back on top before you put the subframe back in? Did you put the plate on the bottom before you put the nut on. I've installed countless sets of IE subframe bushings with no issue.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Faviolosky
      • Nov 2008
      • 154
      there was no OE washer when i took it off, and yes i put the plate on the bottom what does it look like
      • asubimmer
        • 6482
        Yeah there was a washer, it was just fused to the center of the old bushing. Time to take everything back off and do it right!
        • ForcedFirebird
          • Feb 2007
          • 8300
          x3 on the washer, it's a big washer (bout 3" diameter and 3/16" thick)...
          john@m20guru.com
          Links:
          • RobertC
            • Dec 2010
            • 127
            The washers your looking for are the 'Stop Washers'.
            Part Number # 33 33 1 127 496
            Your can order them new from the dealer for about $20 for both.
            www.facebook.com/E30motorwerks
