Min thickness for rear rotors?
  • priapism
    • 1182
    Whats the minimum thickness? About to swap pads, need to know if I need to do rotors too.
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
  • monty23psk
    • Mar 2008
    • 1289
    Depends on rotors sometimes. Looks for a stamp on the hub for the number. Normally it is there if there is not too much surface rust covering it.
    Alex 88 m5 | 91 318is | 19 Subaru Ascent
    BMW Tool Rentals & Fender Roller
      The wear limit of a BMW rotor is 1mm per side. A simple check is to compare the ridge (if there is one) with the thickness of a dime. It the ridge is that high, or nearly that high, replace the rotor.
