broken control arm removal
  • MrMatt2532
    • 24
    Ok, I removed all of the bolts, but i can't get the darn thing off.....in my accident, the control arm basically got bent up real bad and is smashed towards itself. Any tips for getting this things removed....
  • BENdashdash
    Tom is not my friend
    • Aug 2004
    • 2506
    From what I've seen, they normally don't come off without a fight. Grab the end of one of the sides and pull it down as hard as you can. This will cause the other end of the arm to swing up, hitting the body. Do this a few times and it will hopefully loosen.
      • 34844
      you need some sort of penetrating oil, and heat. also, do you have access to the inner ball joints from the top? I used some extensions and the socket and knocked mine out from the top.
