HELP!!! How do I keep these friggin brakes from squealing?
  • MarkH
    • Jun 2005
    • 65
    I put new Brembo rotors on the front if my 325i with PBR Delux Plus pads, and cannot seem to keep them from squealing. I put four coats of Permatex Spray On Anti Squeal, and followed the instructions on how to bed them in (at least as well as I could here in Silicon Valley). But no matter what I try the brakes continue to squeal.
  • BahnE30
    • 1050
    think of it as race car brakes, decent pads always squeel more because the compounds are harsher. either deal with it or get new pads
    i have PBR Ceramics and they squeel like a bitch and it doesn't bother me anymore normally every little creak or anything does but you'll get used to it
    • Digitalwave
      is a poseur
      • 6293
      Deluxe should not squeel bad. You shouldn't have put the anti squeel on before you broke the brakes in though.
      RISING EDGE
      • AndrewBird
        The Mad Scientist
        • 11898
        If you got any dirt/grease on the rotors or the surface of the brake pads, that will make them squeal. Even a dirty thumb print will affect them. Try cleaning the rotor with something non-petroleum based like carb cleaner and see if that helps.
