nuts on CA ball joints
  • zandi
    • Apr 2004
    • 602
    I have new self-locking nuts for all the ball joints on a nwe control arm I'm installing, it tightens on to the bolt on the ball joint for a few turns and then after that it spins along with the 'bolt'(of the ball joint), therefore not tightening up at all anymore. someone said they had the same problem but used air tools and it was fine, but I don't have air tools. what should I do?
  • Jordan
    • 12912
    Use a jack to push the taper up and hold it in place.
    Duh.
    Pay a mechanic man, you aren't one.
    https://mtechniqueabs.com/
    • RCWells
      • 3589
      LOL, good to have you back man. :D
      [THE 501 club - Founding Member]
      • PeaveyBassist
        • Sep 2004
        • 3511
        What Jordan said. Its really easy. Just leave the car on jack stands, then jack up the strut on the outer ball joint. Then tighten the nut. Done.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • Axxe
          • Aug 2004
          • 3355
          You are better off putting the jack underneath the balljoint from the beginning, once those suckers start to spin they sometimes don't stop.
          Keep it slideways!!
          • el bob
            • Feb 2006
            • 348
            Duh.
            Thread bump of the century.
            Just wanted to say this thread (found via search) saved the night for the Scooby front control arm install. I couldn't figure out how to tighten the ball joint nuts since the studs kept spinning.
            Support the bottom of the joints with a floor jack fixed it! :)
            Praise be internetz
            • zandi
              • Apr 2004
              • 602
              Wow, 3 years ago...Happy this helped ya =D
              • Atreus
                • 1846
                jordan would be proud. :P
                1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                1991 325iC - Calypsorot Metallic
                1994 540i - Granitsilber
                Originally posted by scabzzzz
                I've had blunts cock in my mouth, but I'm not gay.
