I just recently replaced my master cylinder with a 25mm, and went to stainless brake lines. I did a normal bleed, but the brake pedal is ROCK HARD now. The car simply will not stop unless I put my entire body into it, and even then it still won't stop.
Is this normal? Because the thing is, on my original MC I had the same problem. (Hence replacing it in the first place) I'm thinking it has something to do with my Booster, since my vacuum SEEMS fine. Can anyone help?
