I'm messing with an e30 whose brakes are sticking on a bit in the front. The car sat for atleast a few years. I believe it's due to clogged lines not allowing the pressure to return to the master cylinder. I don't think it's the master because disconnecting the line at the master doesn't release the pressure. Disconnecting the bleeders and soft line releases the pressure, and disconnecting where the hard lines go into the ABS unit releases the pressure. So, I think the clog is in that hard line (both sides?!) from the wheel well to the ABS unit. I already replaced both soft lines at the wheels, because those were pretty clogged. Calipers and master are off of another good working car.
What do you guys think?
