Made a tool to remove rear subframe bushings
  • omar510
    • Jul 2010
    • 101
    I got this idea from bimmerforums. It makes removing the bushings super simple and the guy in their video did it in less than 5 minutes including jacking up the car. I got the bushing to come out but tried several methods to get the bushing back in but only got it half way in. Anyone have any better ideas? I need to get this car ready for school on monday. Thanks
  • KenC
    King of Kegstands
    • 14396
    Tool looks great.
    Lube and a big hammer?
    Originally posted by Gruelius
    • george graves
      • 20003
      Drop the subframe or make another tool.
      Originally posted by Matt-B
      • omar510
        • Jul 2010
        • 101
        I cant put force on the inner bushing right?
        • george graves
          • 20003
          You mean the center metal tube? You can but it won't do anything for you - it will flex an inch or more and not really move anything.
          I assume you've tried putting the whole weight of the car on the bushing?
          • Van Westervelt
            • 9365
            Bushings into the freezer, then lube them up.
            • omar510
              • Jul 2010
              • 101
              i was thinking about heating them up with a heat gun? but u say colder temps will work better?
              • devon.818
                • Feb 2011
                • 2937
                heat makes soft, and expand.
                cold makes hard, not expand....
                idk never done it but i think that would be the reasoning.
                • omar510
                  • Jul 2010
                  • 101
                  How long in the freezer? Should I use a heat gun to heat the subframe separately and then press them together?
                  • KenC
                    King of Kegstands
                    • 14396
                    Put a 2x4 or something under the one that's halfway in, and use the weight of the car to press it in.
                    • omar510
                      • Jul 2010
                      • 101
                      Tried that. Only went in halfway
                        Drop the subframe and use a Sir Tools subframe bushing kit, or equivalent, to pull the bushing into place.
                        • omar510
                          • Jul 2010
                          • 101
                          Did it with frozen bushings+heated subframe+white lithium grease+bottle jack
                          • Kershaw
                            • 11822
                            i spent 9 hours doing my rear subframes on a previous e30.
                            this should be stickied.
                            AWD > RWD
                            • StereoInstaller1
                              GAS
                              • 22679
                              Best lube for ANY rubber bushing is dish soap. Don't waste your time on anything else, trust me on this.
                              And: a simple 2 jaw puller on the top edge of the subframe with any adequate metal disk will shove that bushing in easy, like 30 seconds easy.
                              Closing SOON!
                              Thanks for 10 years of fun!
