4/1987 325is.
The valve under my master cylinder. Both solid lines run from the master cylinder into this valve then out to the ABS unit/pump.
1. What is it?
-proportioning valve?
-combination valve?
2. Any one know the part number?
-I am sure it is number 7 in this diagram but realoem doesn't list a part number for my VIN(or any other random e30 model/year I looked through). It lists #5 but I'm certain that #5 is not installed on my car.
3. Will there be a drastic change in braking functions and feel if I remove it from the system and run the solid lines straight to the ABS unit?
I've searched on this topic, but to no avail.
I'll get a pic posted in a bit...
Namaste
1. What is it?
-combination valve?
Namaste
