Subframe Bushing Tool?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Does anyone have or know someone who does have the subframe bushing removal tool? Looks like it makes life easy! This Guy
    Thanks
  • Wh33lhop
    • 11705
    It had fucking better for $400.
    paint sucks
    • KVF
      • 297
      Thanks
      PM Monty23psk
        The Sir Tools subframe bushing kit works super well. But unless you plan on doing this job multiple times it is hard to justify the cost. In a like manner the Sir Tools rear bearing kit turns that job into a trivial exercise.
        • csermonet47
          • Jul 2009
          • 937
          Just use a torch and some lag bolts. It isn't that bad really.
          Are Three Vee
          Dad Spec
          • F34R
            sLaughter
            • 12376
            I used this on the trailing arms because I could not get the arm lined up in my press. Just use a torch OP, works like a charm!
            I never used bolts or anything, just a torch and burning rubber!
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • monty23psk
              • Mar 2008
              • 1289
              Thanks KVF..I got it waiting for next customer. Worth it.
              Alex 88 m5 | 91 318is | 19 Subaru Ascent
              BMW Tool Rentals & Fender Roller
              • SkinnyVT
                • Nov 2008
                • 391
                Originally posted by E30 F34R
                II never used bolts or anything, just a torch and burning rubber!
                skip the propane torch and go straight for the mapp gas, 10 minute job
                '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
                • A.J.
                  • 95
                  I got a pitman arm puller from Harbor Freight, ground the ears off, used a three arm puller borrowed from O'Rieleys, and a heat gun. Worked like a charm and cost less than $10. Here's a link to how to make the tool and pull the bushings:
                  • csermonet47
                    • Jul 2009
                    • 937
                    Pro tip: If you torch the rear trailing arm bushings, mine exploded off and shot across my garage on fire, so be careful.
                    Are Three Vee
                    Dad Spec
                    • quickervicar
                      • 1197
                      FWIW, I just returned the tool to Monty23psk. It worked just like it should. Money well-spent, IMHO.
                      • monty23psk
                        • Mar 2008
                        • 1289
                        Thanks J. It is available once I get it back for anyone that is intersted in it.
                        • sam3
                          • May 2007
                          • 206
                          BMW bushing tool
                          The owner of the cars I work on just bought the BMW subframe tool kit, but there are no instructions with it, anybody have a link to the instructions or a video guide?
                          I could probably figure it out but it's reassuring for the customer if you look like you know what you're doing.
                          Thanks
                          • monty23psk
                            • Mar 2008
                            • 1289
                            What brand and model do you have? There are different ones with different instructions. Concept is the same though.
                            • sam3
                              • May 2007
                              • 206
                              Sorry, It's the SIR kit from Pelican
