Massive BBK - pads squealing like a pig
  • emi
    • Jun 2005
    • 80
    I have tried everything. 3 different types of pads, 2 from wilwood, I am noew running greenstuff from ebc. Can't get them to stop squealing. I can't drive the car anymore. I have had it.
    I just put on the greenstuff, which are supposed to the be the quietest. I put the wilwood shims on, and it actually got louder. Took it all apart, cleaned it added goop under the shims. I even added graphite pencil rods into carefully drilled tiny holes. no improvement.
    I'm out of ideas. Please help.
    300mm x 32mm 4x100 with superlite calipers.
  • Eric
    • 5142
    because racecar.
    • Gruelius
      • Oct 2009
      • 298
      raze parts are loud
      see if you can get Akebono pads i hear they are quiet.
      RIP 84 323i coupe 5spd w/ 14psi
      89' 318i
      • e304me
        • Feb 2006
        • 1374
        They are designed for hard braking, not light street driving. Im assuming they only squeak when you are lightly using the brakes? my wilwoods do the same.
        • F34R
          sLaughter
          • 12376
          Should have stayed stock if you dislike pad noise on race brakes
          My advice is get a custom sticker that reads: "You think this car is noisy? you should hear me in bed!"
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • emi
            • Jun 2005
            • 80
            The wilwood track pads are loud, no complaint there. the greenstuff is loud only when cold. they are super quiet when hot, altho they don't bite as well.
            so, this isn't exactly kosher, but i drove in some small nails on each side of the pad between the pad and the caliper slides (it will be a pain to remove) and took the car for a spin... dead quiet! i got some noise after I warmed them up a bit, but that is acceptable, since that does not happen during street driving.
            Should I leave the nails in or get them out?
            • emi
              • Jun 2005
              • 80
              The stock brakes suck!! the sticker might make the noise palatable. Actually putting the car to some good use on the track might help too. The brakes do work really well.
              • JeremyE30autox
                • Dec 2010
                • 404
                My advice is get a custom sticker that reads: "You think this car is noisy? you should hear your GF in bed!"
                Need asap
                Dare 2 Dream Motorsports
                • Dominic49
                  • Feb 2007
                  • 1373
                  the stock brakes are more than adequate for a street car.
                  • Brian D
                    • Mar 2006
                    • 832
                    300mm kit front and rear, Wilwood HP20 pads on the street, not a peep from the brakes.
                    1973 Bavaria
                    • F34R
                      sLaughter
                      • 12376
                      I rebuilt my stock calipers and put on OEM rotors and very good pads for my daily. It was amazing and did the job spot on! I also did SCCA for a season with that setup and was awesome!
                      I personally have the UUC BBK setup so I do know the difference in stock to race setups. If you wanted the bling factor you got it! but there is noise sometimes I guess. Not that I notice it with a gutted interior and all polly racing bushings xD
                      Good luck with figuring it out.
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
