BIG stopping power.... need your opinion
  • revhead888
    • May 2008
    • 149
    So i have a 2j conversion in the works for my bmw e30.
    I have been pondering around forums looking for an appropriate brake kit.
    i have been mainly sold on the 'massive brake kit' but like any aftermarket kit there are pro's and con's given from people.
    so after much confusion on reading forums on which way to go. i ask for your opinion, what would you choose to go if you were needing rather large stopping power for a bmw e30 (will be tracked)
    thanks in advance...
  • deutschman
    • May 2008
    • 5958
    UUC just came out with a kit that is a bit less then the massive kit, and is a direct bolt on design. It is a bit less as well. Seams like a nice set.
    • Fidhle007
      I can fly, motherfucker
      • Oct 2005
      • 7209
      Their both waffleswaffleswaffleswaffleswaffles crap.
      '89 325is S50 Track Montser
      '04 X5 Daily/Tow Vehicle
      http://www.avarestoration.com
      http://www.myspace.com/brendanfiddle
      Click here if you want to be my zombie slave...
      http://www.youtube.com/user/Fidhle007
      • revhead888
        • May 2008
        • 149
        hmm very tempting! thankyou
        shame they don't have a rear break setup also
        • revhead888
          • May 2008
          • 149
          ooh tasty, what size rotor?
          and who makes that one?
          • Dj Buttchug
            • Jun 2010
            • 7688
            need to start looking as well. my stock brakes are not gonna hold
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • Fidhle007
              • Oct 2005
              • 7209
              It's a custom job but I might be able to help you out. It started as a Massive Race kit (older, non-floating option) but I'm using a Wilwood 12.72" rotor instead of the wimpy 11.75" rotor Massive specs. The brackets were made in-house but if you're interested I can get them measured and/or replicated before they go on the car. I'm matching it with a 12.2" rear kit from Ireland Engineering but I have no driving impressions yet as nothing has been installed. Hopefully that will happen soon...
                • 37833
                ^ Gangster shit right there.
                OP, also check out the Ireland Engineering kits, they have a couple options and also offer rear.
                Grover Beach, California
                BimmerHeads.com
                • Fidhle007
                  • Oct 2005
                  • 7209
                  Yeah, their front options weren't up to my lofty standards but they seem like decent setups. Less "Blingy" then the Massive offerings, not as "OEM" as UUC but I'm very happy with the quality of my rear kit so I imagine the fronts can't be any worse...
                  • bimmerteck
                    • 762
                    I'm running one of Massive's sport kits and love that it will squeeze under a 15" set of wheels for the track if need be. If it wasn't a 'vert I would likely have the race setup but these are fine for hard street and occasional track use.
                    Pictured under 16x7 BBS RGF
                    • Fidhle007
                      • Oct 2005
                      • 7209
                      Yeah, it's all about tradeoffs. Stopping power and heat handling will put you in Massive Race territory, wheel clearance will lead you towards UUC or IE. Or you can do what I did if you're gangsta...
                      • SkinnyVT
                        • Nov 2008
                        • 391
                        Fidhle, I'm wondering what you find blingy about Lee's kits? Also what are you stopping that you found other kits were being overheated?
                        Full disclosure, I am running an early Massive sport kit, PFC01 pads, Motul fluid and no ducting.
                        '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
                        • revhead888
                          • May 2008
                          • 149
                          sounds awesome the brake setup your creating!
                          i was looking at the ireland engineering group for their brakes but after a bit of research found that the massive brake kit was a better option.
                          As for wheel clearance i don't believe this will be an issue as i have huge adapters to space my road going wheels out anyway, and ill just buy track wheels to suit.
                          As i live in australia freight costs normally kill me. so im trying to get it all sorted within the next month or two as a mate is bringing a car back and ill just chuck all the new goodies in the car
                          • Fidhle007
                            • Oct 2005
                            • 7209
                            Lee's kits have a lot of "pretty" machining which looks fantastic but puts the price higher then the more basic IE offerings. I've only had overheating problems with a Massive Street kit (on the track with S50 power) but Lee has long ranted about the inability of narrower rotors in other manufacturers kits to handle track temps.
                              • 37833
                              Now I know UUC is best for wheel clearance (and I think I'll be going with their kit) but from what I saw on IE's website they are using a Wilwood caliper now. I don't know a ton about this stuff but it seems like the same one Lee is using? I know the older IE kits used a Cobra caliper, right?
                              BimmerHeads.com
