NEED brake help
  • mo diesil
    • Jan 2011
    • 275
    NEED brake help
    so the front brakes mainly the front drivers side is dragging on my 87 m5nv swapped e30 and at this point it has basicly worn the rotor completly away on the out most part,it start wearing unevenly i noticed at first, but now the whole rotor is trashed be it only 3 months old(replaced all brakes and rotors when car was purchased due to the fact it had warped rotors )
    does anyone have an idea or a clue as to what may cause this?? this whole situation is not helping my day..
    Something is causing the caliper not to release. That could be from a binding caliper, a bad soft brake line, or a fault in the ABS unit. Start by rebuilding the calipers (or replacing them) and replacing the soft brake lines.
    • mo diesil
      • Jan 2011
      • 275
      what if its a fault in the ABS unit?
      • bmwguy325is
        • May 2011
        • 1262
        BMW calipers are floating calipers. You have to grease the guides from time to time. Or loosen them up when you swap pads. Or they are called caliper bushings.
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • mo diesil
          • Jan 2011
          • 275
          note that the slot is worn away
          you can see how its worn unevenly
          notice the passenger side is not that way
          • sweet6e30
            • Feb 2011
            • 531
            the slider pins sieze up which prevents the caliper from moving evenly on both sides of the rotor. Clem em up on a wire wheel and clean out the insides of the caliper cradle where the slider pins sit. then be liberal with antisieze, check the little boots for holes, if they are torn or damaged replace them to prevent water and debris from pooching up your pins and sliders.
            if your going at it rebuilding the calipers, might as well replace the brake lines with some ss lines and put new bleeders. ( PUT ANTISIEZE ON THE BLEEDER THREADS!!)
            my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
