Do I need a poly diff mount to go with poly SFBs?
  • Wishno87
    • 6025
    #31
    So delrin is the way to go then? How should I best lubricate them? I still have a huge pipe of lucas red n' tacky from my camber plates. Can I use that?
      • 34844
      #32
      you don't lube delrin. it's self lubricating.
      • shiboujin
        • Feb 2006
        • 2791
        #33
        Delrin is technically "Self lubricating". I did use some grease on the inside of the metal insert though
        I'm not sure if it's how you want to go. streetable would be 80A not delrin. If you want hard for that herra frush, go aluminum everything and delrin for the trailing arm bushings. Might as well get the akg raised subframe solid mount kit.
        • Wishno87
          • 6025
          #34
          Where is the best place to find the delrin TABs? On turner they are 100$
          I also already have treehouse cabs and ground controls with the race camber plates. Since I already have no rubber up front how much harsher can it actually get?
          • Wishno87
            • 6025
            #35
            Turns(no pun intended) out the turner ones are urethane and IE doesn't sell delrin tabs either.
            • nrubenstein
              • 3148
              #36
              A lot. You feel NVH from the rear a lot more than you do from the front.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • shiboujin
                • Feb 2006
                • 2791
                #37
                I forget where I got my 75d trailing arm bushings. I think I got everything from akg.
                • LJ851
                  • 7919
                  #38
                  This is true. Your subframe isolates your differential,etc. from the chassis and that sucker makes a lot of NVH.
                  Lorin
                  The M30 is God's engine.
                  • Wishno87
                    • 6025
                    #39
                    So if im already going 80A SFBs and MZ3 diff bushing then delrin TABs wont make it much worse?
                      • 34844
                      #40
                      I wouldn't think so, since the NVH from the TA's will still have to go through the subframe.
                      • FredK
                        • 14763
                        #41
                        I've run an entirely AKG 75D rear end for 35,000 miles over the past 2 years. It isn't harsh.
                        75D transmission mounts, however, are ridiculous.
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #42
                          IMO 75d is the only real upgrade for the trailing arms. Anything less will bind or be stock rubber. I'd love a spherical bearing upgrade to be within simple price range tho.
                          • Wishno87
                            • 6025
                            #43
                            AKG only has 75d polyurethane. Should I get that or look for 75d delrin?
                            • shiboujin
                              • Feb 2006
                              • 2791
                              #44
                              I have the poly akg ones. I dont' think anyone actually makes the delrin version.
                              • Wishno87
                                • 6025
                                #45
                                Ahh okay. So those would in fact need to be lubricated correct?
