What is broken?
  • chappys4life
    • Aug 2011
    • 132
    What is broken?
    I was in a minor wreck solo car accident lost control did a spin with a slide into a smaller tree. The fender was hit right at the very back arch and dented in, wheel bent and you can see some rubbing on the strut when I drove it home.
    Here is the wreck damage:
    Then I changed the ride side wheel, tire, control arm, tie rod assembly, cab, and new lollipop bracket. After a better looking with it sitting the tire is really kicked out. Could I have damage the knuckle and strut? Or what could it be?
    You may have damaged the strut/knuckle or moved the shock tower. The first thing to do would be to replace the strut/knuckle. Then see if that wheel still has excess camber, If it does take the car to a frame shop.
    • bastianshaw
      • Jan 2007
      • 2210
      yeA frame maybe
      • Jaxx_
        • Dec 2009
        • 1880
        that's some serious movement if it was the shock tower. I've seen struts bend from impacts. I had about 3 degrees of negative camber from an impact similar to yours. Frame wasn't damaged, however.
        I would also suggest measuring your shock towers and comparing them to someone with the same model year to see if they have shifted significantly.
        • chappys4life
          • Aug 2011
          • 132
          Found a strut housing so replacing it when it comes in. Once that is done taking it to a frame shop.
          • E30_fiend
            • Apr 2006
            • 7348
            I would say your upper strut mount is bent to hell.
            • IRON-E
              • 16548
              Did you replace your tie rod on that side?
              @IRON-E30 aka Edwin:D
              • lbreevesii
                • Aug 2009
                • 412
                Hopefully its just the strut tube/upright. My car came with a bent one(-1.3* camber at stock height). Picked up a replacement set for cheap and one of those is bent badly as well.
                I don't always wreck cars, but when I do I wreck them into trees.
                91' 318is S50 swap - The Black Widow
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5275
                  OP should repeat this process a few times and market a "hellaflush" front camber kit.
                  Originally posted by priapism
                  Originally posted by shameson
                  • xxlbimmer
                    • Dec 2010
                    • 156
                    Hood gap doesn't look too radically smashed, probably not the strut tower. That much neg camber would need 2-3 inches of motion at the top. I would think a strut tower bent in would bring the fender into the hood, thus preventing from closing.
                    Your milage might vary!!
                    Chris Leone
                    chrisleonemotorsports.com
                    rollcages and fabrication
                    Remember cross threading is the only thing stronger than loctite!!
