G60 tank calipers. Those things weigh a ton, Made for stopping 5K turbos.
Scirocco discs + Saab binders
here is my mock-up. The bracket is very crude as it was only for test fitting. the final brackets will be made of 1/4" stainless.
The Brembos in the picture above.
According to the post, The one from Latvia, they come with Brembo rotors, hats, and Brembo calipers for $600 US (500 Euro). Are these available in the US? Is that price right? What brand are the coil overs?
actually they aren't g-60 calipers..they are the 5k turbo tank stoppers!Originally posted by SchnellerVertG60 tank calipers. Those things weigh a ton, Made for stopping 5K turbos.
gregseien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
yeah, arent those the Girling-60's?Originally posted by der affeactually they aren't g-60 calipers..they are the 5k turbo tank stoppers!
greg
g-60's are single piston, turbo 5k's quattro only, are 2 piston, basicaly made the kit that autotech sells myself...just without the bracket/adapter that you don't really need anyways. my g-60 s/s lines wouldn't work either (had g-60 calipers first) had to get longerseien Sie größer, als Sie erscheinen
The corrado G60 had single piston Girling 54 calipers (G54) and The big audi's had dual piston Girling 60 calipers (G60)
Nice brakes (weigh a ton though) a freind of mine had them on his Corrado.
how much work to open the rotor .040 each time new ones are bought? I take it it has to be done professionally, not just with a dremel or something?Originally posted by 2002maniacI'm using corrado rotors and e34 540i calipers and I just finished mocking it all up on a spare strut I have.
I think e28 calipers might be a better idea, but I got the e34 calipers for free.
When I get back to work on the 2nd of jan. I will make the final brackets and take some pics. This setup wont fit under my winter B-caps so I'm not really in too much of a hurry to get it finished.
Besides the brackets it should be an easy swap. The centerbore of the VW rotor needs to be opened up ~.040" IIRC to clear the E30 hub. The e34 carrier needs to be clearanced and the backing plates need to be trimmed also. I could make a batch of brackets if you guys want.
The e34 caliper w/carrier weighs 4.5lbs more than the e30 setup. Not as much as i expected.
do you know if 15" wheels will work?Comment
it has do be done on a lathe, but it is very simple. It took me about 5 min to do 2 rotors. I doubt a shop would charge much to do it.Originally posted by nickmp0werhow much work to open the rotor .040 each time new ones are bought? I take it it has to be done professionally, not just with a dremel or something?
Yes, that is the whole idea!do you know if 15" wheels will work?
