Rear camber
  • shoguncro
    • May 2011
    • 115
    Rear camber
    Also i have a rear camber kit i want to go in -
    How much can i go in - with the camber plates ?
    also with this
    • 37833
    Wait, you're trying to add more negative camber? Why?
    Grover Beach, California
    BimmerHeads.com
    • shoguncro
      • May 2011
      • 115
      Yes i want more negativ camber
      Becouse of this
      9j et0
      And no i dont want to roll my fenders
      • Wishno87
        • 6025
        Just lower your car. It happens automagically. I had three degrees when I spun my coils down.
        • priapism
          • 1182
          Your tires are stretched too much, that's one reason that's happening. What kind of pressure are you running? Looks like you're running too low.
          -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
          • shoguncro
            • May 2011
            • 115
            yes i am to low and iam not static enought
            i am running 215/40 on 9j
            i only can roll my fenders but that looks like shit
            or i can get more camber and that will solve my problem
            this is how it sits now
            • priapism
              • 1182
              The problem is your tires don't fit your rims. Negative camber will just move the uneven wear from the outside to the inside.
              • shoguncro
                • May 2011
                • 115
                Also more strech ? 195 50 tyre
                or should i remove my 15mm spacer but then it looks like shit, becouse no poke
                  • 37833
                  I like how you think rolled fenders "look like shit" but you want your wheel to sit fucking sideways.
                  Good luck, hopefully the poke fanboys can help you out here.
                  BimmerHeads.com
                  • Wishno87
                    • 6025
                    I don't think you understand what fender rolling is. You can not distinguish a rolled fender from an unrolled render unless you stick your fingers in there or shove your head in the wheel well.
                      It looks to me that you have more than 3deg or rear camber now. I'd say you need to re-think your choice of wheels/tires.
                      We run 3-3.5deg of rear camber on race cars (and zero to 1/16" total toe) for performance and accept the higher tire wear. On a street car that makes no sense.
                      • Wh33lhop
                        • 11705
                        Neither does running a 215 section tire on a 9" wheel. ;)
                        paint sucks
                        • E30SPDFRK
                          • 5712
                          I did this, running -6 in the rear. You could probably get more if you put the camber adjustment eccentrics on the outside rather than the inside like me, but you don't need it. I gained about 20mm of clearance this way and was able to take my 16x10 et16 from sticking out 7mm to tucked inside with plenty of room
                          Make sure you correct the toe at the same time or else your tires will be gone quite fast. Mines set at slightly more than factory spec and my tires have been doing fine.
                          Byron
                          Leichtbau
                          • shoguncro
                            • May 2011
                            • 115
                            and what would you run on 9j ?
                            • masduro
                              • Aug 2011
                              • 221
                              Yes, roll the inner lip to prevent cutting the side wall of the tire. You can do this without altering the 'look' of the fender.
