Rear camber
    • 34844
    Originally posted by shoguncro
    and what would you run on 9j ?
    a 235 minimum ;)
    • shoguncro
      • May 2011
      • 115
      Originally posted by nando
      a 235 minimum ;)
      It would be only worse
      and its gay, e30 should be a wow carm not a race car or daily driver becouse i have more cars
      i wil grind dnow my spacer for 5mm
      • trackjunkie21
        • Jan 2010
        • 3962
        Right, because the e30 was designed from the factory to look like a hovercraft. I really want this stance shit to die already.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • bimmer630
          • 1230
          I have lowered springs with no camber/toe correction, and 16x8's with 225/45r16 tires, and the inside edge of these tires wears out like crazy. I dont know how you guys drive on stuff with that goofy stance, Mine is like that because I havent gotten around to welding in camber/toe kits.. which I actually just ordered...
          Isnt a correctly sized wheel/tire alot "cooler" than having a car that looks like its got a bent rear axle?
