Knock when applying brakes
  • gtdragon980
    • Jun 2008
    • 1808
    Yesterday as I was driving home from the dealership, I noticed when I apply my brakes a knock would occur up-front. It would only knock once as I begin applying brakes, but the car would still brake fine. I was beginning to think maybe the master cylinder is going, but before I buy anything to replace, I would like some other ideas as to what could cause this. To me it sounds more like a knock or a clunk, no grinding or metallic noises. It literally sounds like someone tapped a hammer on the other side of the firewall. Any idea's are welcomed! Thanks!
    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
    Originally posted by scabzzzz
    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
    1989 325i - Project/weekend driver
    2002 325i - DD
    2005 Suzuki SV650 - Toy
  • immajackuup
    • Dec 2010
    • 1132
    strut bearing is bad,does it knock when you only apply brake???
      Loose caliper or carrier bolts, a bad strut bearing, bad control arm, or bad control arm bushing/mount all all possible causes. Don't drive the car until the cause is identified and fixed.
      • gtdragon980
        • Jun 2008
        • 1808
        It only knocks once when first applying the brakes, and each time I apply them. I don't notice it when the car is parked, but if i'm on the move or have been driving for a while and come to a stop, i can tap the brakes at a standstill and still hear the knock. So, from what I recollect from driving it yesterday, it doesn't only knock while moving, it can be at a stop and still knock. Maybe air in the system?
        2002 325i - DD
          Since you can cause the noise with the car not moving I'd look to the caliper or carrier (or maybe wheel bearings). I don't see how air in the system could cause noise.
          • gtdragon980
            • Jun 2008
            • 1808
            Okay, when I get off work I'll take a look. Will report back.
            2002 325i - DD
            • gtdragon980
              • Jun 2008
              • 1808
              Well, after driving it yesterday I found out that it is in fact either the ball joint or the CAB. The knock only occurs while the car is moving, and not when it's at a standstill unlike my previous description. Not only that, but the same knock occurs when hitting bumps and it is centered right around the driver wheel.
              2002 325i - DD
              • oxymoron
                • Nov 2011
                • 356
                this happened to me, found out my brake pads and sliders were bone dry i hit them with nice brake paste and it stopped
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5240
                  Happened to me a week ago as my wheel was about to fall off. Only difference was I also experienced a vibration at 60kph+
                  Originally posted by priapism
                  Originally posted by shameson
                  • lambo
                    Captain Scene Points
                    • 10953
                    Shock mounts, maybe?
                    • KenC
                      King of Kegstands
                      • 14396
                      So your caliper and carrier bolts are all tight?
                      Originally posted by Gruelius
                      • acolella76
                        • 2950
                        don't brake?
                        -Alex
