Brake makeover
  • mbonanni
    • Sep 2011
    • 6236
    Brake makeover
    Okay, I am reusing this thread for a new topic.
    I am doing a brake makeover. This is for my DD so it does not have to be super high performance. I am looking to do a most of the brakes, but not all. ABS sensors seem expensive (ordering from pelican parts).
    So far I have
    front/rear brake sensors
    front/rear caliper rebuild
    I plan to do rotors and brake pads. Which rotors and which pads? anything else you guys reccomend?
  • shoguncro
    • May 2011
    • 115
    its written on your calipers who is the manufacturer
    and yes thats all you need, maybe you need a new piston but you can not know until you disansemble your old calipers
    • mbonanni
      • Sep 2011
      • 6236
      Thats what I assumed, I shoulda checked first. but it was like 35 degrees outside. haha
      thanks
      • mlytle64
        • Jan 2010
        • 141
        no, that is not all you need.
        you also need the guide pin bushings(2) or a guide pin boot..depending upon which brand of calipers you have. these are rubber wear parts just like the seal kit you listed.
        marshall
        75 M2
        87 325
        97 m3
        02 325it
        • mbonanni
          • Sep 2011
          • 6236
          I tried to look but could not fond a name. whereght have to xlean it. will it be? I m
            The rear calipers will be ATE. The fronts, depending on where the car was built could be either. You have to look at the front calipers to figure out which you have. The upper diagram on http://www.realoem.com/bmw/partgrp.d...21&hg=34&fg=05 shows girling calipers. The noticeable difference is how the calipers mount to the carrier.
            • mbonanni
              • Sep 2011
              • 6236
              Thank you.
              Mostly thank you for that website, will help a lot.
              • mlytle64
                • Jan 2010
                • 141
                a few pic of process for you. i just did a front set today.
                crusty old seals
                piston out
                piston in with new seal
                new seals, guide pin bushings, brake hose
                marshall
                75 M2
                87 325
                97 m3
                02 325it
                • SkiFree
                  • Jun 2011
                  • 2766
                  Something else to consider if you don't want to worry about the rubber guide pin bushings....go with brass. You can find them from just about anybody specializing in BMW parts.
                  ADAMS Autosport
                  • mlytle64
                    • Jan 2010
                    • 141
                    i would not put the brass ones on a street car. unless you do monthly maint on the brakes. there is nothing to keep dirt/crap out of the bushing..which gets in and binds up the pin.
                    i had them on a race car once...but that car got the brakes gone over every weekend.
                    nothing to worry about with the rubber bushings. they last as long as the caliper seals do and require no maint other than a little grease when you change brake pads.
                    marshall
                    75 M2
                    87 325
                    97 m3
                    02 325it
                    • SkiFree
                      • Jun 2011
                      • 2766
                      ^^Interesting, that makes logical sense to me, never put much thought into it I guess.
                      ADAMS Autosport
                      • mbonanni
                        • Sep 2011
                        • 6236
                        thanks guys!
                        I still need to figure out which caliper I have up front. /:
                        • mlytle64
                          • Jan 2010
                          • 141
                          look at the diagrams on realoem.com, then look at your calipers. the pics i posted are of the ATE fronts.
                          marshall
                          75 M2
                          87 325
                          97 m3
                          02 325it
                            A month? I would not drive a car with brass guide bushing on the street more than a week before cleaning and relubricating the guide pins.
                            I ran brass bushings for a while on the race car but found that they didn't work any better than fresh rubber bushing. The hassle of cleaning and lubing the guide pins after each track weekend wasn't worth it. Now the car has rubber bushings, which get replaced each year when I rebuild the calipers.
                            • mbonanni
                              • Sep 2011
                              • 6236
                              I hate ATE rears which someone posted and Girling fronts.
                              Kinda sucks, the Girling guide bushing rebuild kit is more expensive at $30 a piece at Pelican Parts.
