brake booster delete...need help...
  • gooseadrian
    • Aug 2011
    • 284
    i need to know the pros and cons of deleteing a brake booster.
    thanks r3v
    Fuck you buddy
  • TurboJake
    • 3780
    Pro's:
    More brake pedal feedback
    Con's:
    More foot/leg pressure needed
    Notable situations where it won't be a good thing:
    Panic braking
    Leave Me Transaction Feedback
    • Jaxx_
      • Dec 2009
      • 1880
      less weight
      no pedal difference between on and off the throttle. Good for racing situations where you might be at WOT but don't want to lift for a corner for example.
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        sounds like a bad idea to me.... hahha
          • 37833
          If you have to ask, it's not for you.
          Grover Beach, California
          BimmerHeads.com
          • AndrewBird
            The Mad Scientist
            • 11898
            Running a master cylinder that was designed to be used with a booster without one is a bad idea, however, running one that was never designed to have a booster in the first place is fine. That being said, I don't think any e30 ever came without a booster.
            • gooseadrian
              • Aug 2011
              • 284
              thanks guys just curious. i was just wondering cause i see a lot of people do it on the project forum.
              happy new years. dont drink and drive!!!
              Fuck you buddy
              • fporro
                • 1860
                how about relocating it, like on some 5 and 7 series.
                can be retrofited
                • george graves
                  • 20003
                  A.) Drive to an empty parking lot
                  B.) undo the vacuum line to the booster
                  C.) Pump the brake pedal a dozen times
                  D.) Now drive around
                  You'll crap yourself at how crappy your brakes will be. You'll just about break your seat back trying to come to a stop.
                  Originally posted by Matt-B
                  • !kid
                    • 1362
                    That's using the stock pedal ratio. If someone is going going to do a manual brake swap they will be changing the pedal ratio as well as possibly the the master cylinder it self To one of a different size. Your comparing apples to oranges.
                    :borg:
                    • acolella76
                      • 2950
                      Originally posted by Jaxx_
                      less weight
                      :rofl:
                      -Alex
                      • TobyB
                        • 5297
                        The ability to threshold brake effectively would be a benefit.
                        As would your new huge right leg.
                        You might break your seat mounts, though...
                        If you're not up for redesigning brake systems, I wouldn't do it...
                        t
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          you can't threshold brake effectively with a brake booster? news to me.
                          Originally posted by acolella76
                          :rofl:
                          unsure what's funny, honestly.
                          • TobyB
                            • 5297
                            Nope, the lag inherent in the BMW booster system (and probably all boosters, but 2002's and E30's are my data points)
                            means that once you get enough brake on to lock a caliper, you have to lift significantly
                            to get it to unlock. Then you have to modulate back on to get brake force back up,
                            and that's hard to do quickly through the booster without locking again.
                            Took the booster off the 2002 race car and it was probably the best thing I ever did for
                            the car.
                            The increased pedal pressure probably helped, too (different masters, balance bar, etc)
                            but the ability to leave a black mark 6" long instead of 10 feet was enlightening...
                            and the Pro3 cars I've driven behave about the same way.
                            They were boostered....
                            That's been my experience, anywhich.
                            t
