318i Drum to disc?
  • MikeM10
    • Sep 2011
    • 19
    318i Drum to disc?
    Could i swap some four lug disc brakes from a later 3 Series onto a 318i with drum brakes? What parts would be involved?
  • Jean
    • 18228
    If you mean later as in from another e30, yes. Get complete trailing arms. I did this, as many others on my 318i
    • TurboJake
      • 3780
      Trailing arm assemblies.
      Voila!
      Leave Me Transaction Feedback
      • jeffnhiscars
        • Jun 2011
        • 6010
        You will also need the ebrake cables from the donor car
        Alice the Time Capsule
        • Holland
          • Nov 2008
          • 7209
          E brake cables, trailing arms, calipers, brake lines. Don't forget the front as well, later cars have wider vented discs up front so front rotors and calipers are needed. Would be a good idea to upgrade the master cylinder as well, since the bias will be off. Bias valves between drum and disc cars are the same.
          Originally posted by DEV0 E30
