318i front rotors to 325e
  • MikeM10
    • Sep 2011
    • 19
    So i plan on switching my front 318i rotors to the vented 325e rotors in the front. Its my understanding that i pretty much just need the calipers rotors and pads to make it work. I also heard that the master cylinder in the 318i has a smaller bore than the 325e's. so my question is if i justs keep my 318i master cylinder will it affect my braking? any help is appreciated.
  • TG Goose
    • Jul 2011
    • 234
    i'm running 1990 325i brakes on my 1984 318i. You need the rotors, calipers and caliper brackets. Pads are the same.
    ______________________________________
    1984 LSB 318i - Sold
    1986 325i - Motor Swapped Track Car Project
    1995 318ti - Sold
    1999 540iA - Daily Driver
    • irish44j
      • 2763
      m/c works fine. I'm running full 325i brakes (including the rear discs) with no issues on my early 318i.
      Stage rally/rallycross e30 build/competition journal
      Track/street e21 build
      visit Condor Speed Shop
      visit Motorsport Hardware
      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
      • Jaxx_
        • Dec 2009
        • 1880
        it will work, but apparently it is not properly portioned. that's all. I'm not really sure what the actual distribution is.
        • TobyB
          • 5296
          Just make sure you have the 20mm master. According to realoem, you should.
          That also went onto earlier 325's...
          Measure the bore on the calipers. I'd be a bit surprised if they aren't both 48mm...
          t
          • E30RedtopSR
            • 202
            318 master works, yes, barely. When I converted my 84 318i to rear disc and 325 brakes it was pathetic. 318 uses a stepped 19mm/??mm master for the rear drum. I went to a 23 mm master and what a difference.
