Where to buy? Delrin TA bushings.
  • Wishno87
    • 6025
    I can only find poly. Where can I get them in delrin?
  • Wishno87
    • 6025
    Up
      • 37833
      Why do you want rock hard bushings? ;)
      Grover Beach, California
      BimmerHeads.com
      • Wishno87
        • 6025
        It was the conclusion I was brought to in this thread.
        • xxlbimmer
          • Dec 2010
          • 156
          I got a set of ertalon from Lencas on here. They seem to be very high quality. Cheaper than anybody here in the states!!
          Chris Leone
          chrisleonemotorsports.com
          rollcages and fabrication
          Remember cross threading is the only thing stronger than loctite!!
          • Wishno87
            • 6025
            Do they have the same sort of self lubricating properties as delrin? That's why I want them over a hard poly.
            • TobyB
              • 5280
              well, duh, who doesn't???
              Actually, rock fractures and aluminum galls, so if spherical bearings
              are hard to find and set up and maintain (they are)
              Delrin's made the rear of 3 of our 2002s work for about a decade....
              ...with surprisingly little fuss...
              Ireland used to sell them...
              t
              • xwill112x
                • Jan 2009
                • 4236
                OEM rubber is the way to go on TA bushings. Poly for just about everything else.
                • TobyB
                  • 5280
                  i respectfully disagree...
                  ...if you're concerned about rear toe changes under power and braking...
                  t
                  • Wishno87
                    • 6025
                    Up.
