Help with Brakes
    Help with Brakes
    I checked the front brakes on my 92 iC yesterday, and the outer pad on the passenger side brake is completely worn down to the backing plate. The brakes are stock Girling, and the pads/rotors were replaced less than 10k miles ago. The other 3 front pads look barely worn.
    I'm hoping the collective wisdom of the forum can help me diagnose the problem. Would this be caused by a stuck caliper piston, bad caliper, or something else worn out that's keeping the caliper from floating correctly?
    Thanks in advance!
    Cory
    1992 325i Cabrio
    1988 320i Touring
    2000 M5
    1977 530i
    2015 328i - Euro Delivery/Performance Center Delivery
    BMWCCA
    E30CCA
    A bad soft line or sticking caliper will be the cause of that.
      Great info. Thanks!
      1992 325i Cabrio
      1988 320i Touring
      2000 M5
      1977 530i
      BMWCCA
      E30CCA
        Jim,
        I noticed in a post of yours from another thread that you replace the guide bushings regularly on your Spec E30. My street E30 has 100k miles and I think the bushings are original. How difficult is the job as a first-time DIY? Any special tools required? Does the pad carrier need to be heated to get the old bushing out, and does the new bushing need to be pressed in?
        Thanks, Cory
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        BMWCCA
        E30CCA
          Assuming we are talking about ATE calipers, You just pull out the old bushings (they may tear) and push in the new ones by hand. A bit of liquid soap makes it easier to install the new bushings. Girling calipers don't have replaceable bushings.
            Sorry - should have been more clear. My calipers are Girling. So is the bushing not a wear item on the Girlings, or does the whole caliper need to be replaced if it's not floating freely?
            Sorry for the noob questions. Thanks for helping out a fellow CCA member.
            Cory
            1992 325i Cabrio
            1988 320i Touring
            2000 M5
            1977 530i
            BMWCCA
            E30CCA
              If the bearing points for the guide bolts are worn on Girling calipers replacement is the only option.
                Thanks!
                1992 325i Cabrio
                1988 320i Touring
                2000 M5
                1977 530i
                BMWCCA
                E30CCA
