318IS Control Arm Replacement
  • VANOS714
    • Nov 2011
    • 1195
    Never knew what a pain in the ass changing the right control arm would be.
    The left side was very easy as you have room to use a wrench or socket to loosen the top nut. I removed the sway bar to give me more room but still no luck on gettting a ratchet on there. Changed the the contol arm bushings with some nice polyurethane bushings. Changing the tie rods as well. Any pointers feel free to post.
  • VANOS714
    • Nov 2011
    • 1195
    All finished... Just need the right tools to get the job done.
    • drumad
      • Aug 2009
      • 1700
      You should probably post what you did/used so future searches can benefit from this.
      2008 335i - n54b30
      1991 318i - m52b28
      1994 fzj80 - LAND CRUSHER
      • Mr. Tasty
        • Jul 2011
        • 3421
        I am having extreme troubles with the drivers side control arm. The Ball joint toward the middle of the car. I can rotate the nut but the joint spins. I have put vise clamp on the bolt and still rotates. Also did the jack trick. No luck. Car has been up on jacks for 4 days now.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • drumad
          • Aug 2009
          • 1700
          Sounds like you need to put more pressure on that jack.
          2008 335i - n54b30
          1991 318i - m52b28
          • Mr. Tasty
            • Jul 2011
            • 3421
            lifted it about 3 inches off from the jack stand.
            (Daily Driver)
            KW V2 Coilovers
            • drumad
              • Aug 2009
              • 1700
              That's a bit dangerous. Torch tiem?
              2008 335i - n54b30
              1991 318i - m52b28
              • Mr. Tasty
                • Jul 2011
                • 3421
                yea, i need to get a torch.
                (Daily Driver)
                KW V2 Coilovers
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  what about cutting through the the ball joint stud?
                  (Daily Driver)
                  KW V2 Coilovers
                  • drumad
                    • Aug 2009
                    • 1700
                    that's more of a last resort
                    2008 335i - n54b30
                    1991 318i - m52b28
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      its kinda getting there. I have soaked the nut in PB for 4 days straight
                      (Daily Driver)
                      KW V2 Coilovers
                      • bmwguy325is
                        • May 2011
                        • 1263
                        I ussually put the jack stand right under the inner ball joint. Im not sure what the jack trick is no sorry if this is redundant.
                        Id imagine cutting could be a challenge.
                        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                        • peytonracer4
                          • May 2011
                          • 524
                          are you using a wrench? i had this same thing happen on the outer ball joint. had my car sitting on stands for 2 months.
                          you need to hit the nut with an impact wrench. a socket wrench just made it spin but i jack the ball joint up and hit it with an impact wrench and it shocked it off. thank god.
                          have someone stand on the front of your car somewhere to apply just a little more pressure on the jack before you do this for an advantage.
                          • VANOS714
                            • Nov 2011
                            • 1195
                            I did mine on a electric lift so it was not a hassle. I removed the heat shield and loosen the sway bar. I'm managed to squeeze a 22mm socket. Also be sure to pull out swaybar links. I should of taken pictures step by step Damn it. I was just to frustrated trying to get my car done.
                            • VANOS714
                              • Nov 2011
                              • 1195
                              Torch that son of a gun....
