318IS Control Arm Replacement
  • Killacortes
    • 1937
    How hard were the tie rods to do?
    r3v does not fuck around. First you get banned, then they shoot you
    • VANOS714
      • Nov 2011
      • 1195
      they were easy theyre held in by a locking clip, all you gotta do is bend the clip the opposite way and get some channellocks and unscrew them.
      • davy87nj
        • Feb 2012
        • 16
        air or electric impact should pull them off, a socket wrench will just spin the joint.
        • Mr. Tasty
          • Jul 2011
          • 3421
          I don't know, its such a tight space. Don't think I could get an impact wrench in there. Its the drivers side
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • VANOS714
            • Nov 2011
            • 1195
            if you mean to remove from the strut assembly, i used a swivel socket and works perfectly with air tool. just make sure if you dont use a pickle fork, screw the nut by hand and hammer it and it should come off.
            • Mr. Tasty
              • Jul 2011
              • 3421
              nope, subframe
              (Daily Driver)
              KW V2 Coilovers
              • matt0300
                • 549
                Just did both control arms today. My tool of choice is the torch Haha just torch the Shit out of anything and it comes off like butter.
                • VANOS714
                  • Nov 2011
                  • 1195
                  lol I was really close on using a torch as well.
                  • GOT8SPD
                    • 270
                    So i got a 22mm socket and a flex head wrench, but i can't get it to fit over the nut on the driver side! Any tips?
                    • GOT8SPD
                      • 270
                      http://www.lowes.com/pd_337621-25428...7C1&facetInfo=
                      So i ended up going to Lowe's and picking up a 7/8s combo wrench...7/8s is pretty much 22mm....couldn't have done it without this tool.
                      I had to remove the sway bar...I'm not sure but the passenger side was 10x harder than the driver side....
                      • Colby.325e
                        • Apr 2012
                        • 413
                        I did both sides yesterday. Passenger side was harder, but I was able to get it done with a standard 22mm wrench I snagged from NAPA. It was a very tedious process, I had to turn it slightly, rotate wrench, and repeat about a million times. I did most of the loosening above through the engine bay, and found a hole above the sway bar to fit my hand and tighten it from underneath. I guess I got lucky.. Only issue I had was that I broke one of the sway link brackets, but luckily there's a guy about an hour away parting and e30 who hooked me up.
                        Front end feels way better.
                        For clarity, I did not remove the sway bar. I did remove the heat shield.
                        1986 325e - RIP
                        1987 528e - Sold
                        1989 325iX - Parted Out
                        1991 318iS - Sold
                        1991 325iS - Current
                        • Cletonius
                          • 2809
                          I ended up using an angle grinder and cutting the ball joint stud from underneath. I was able to get it most of the way out and then the nut got stuck. There's a bunch of shit there on a 325 so I didn't want to torch.
                          After the stud was cut I grabbed the end with vise grips and put a wrench on the nut to finish it off.
                          For the right side, I cut a 7/8" gear wrench in half and used that in there. Was way easier than fighting a regular wrench or crowfoot.
                          - Josh
                          1990 325is
                          Need a shift boot?
                          Looking to buy shift boot frames, PM if you have one to sell
                          Here's what happens when you let the internet pick your license plate
