CAB bolt broke in frame
  • gtdragon980
    • Jun 2008
    • 1808
    Well, as the title states, the bolt for the cab broke off as I was tightening it with a impact...
    To make matters worse, I found out that the PO also broke a bolt off in the second hole, so I have no way of mounting my CAB at all. So, I'm going to attempt using an extractor to remove it, but if it does not want to back out since it is really rusty, I'm going to have to drill it out. Doing so may screw my threads up and I will need to heli-coil the threads. My question is, does anybody know what size heli-coil I should get for this particular issue? I know its an m10, but I need to know the length of the hole for how long the heli-coil should be, and I don't have any means of finding it out as of right now. Thanks in advance!
    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
    Originally posted by scabzzzz
    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
    1989 325i - Project/weekend driver
    2002 325i - DD
    2005 Suzuki SV650 - Toy
  • KEVORM
    • Jul 2011
    • 237
    i would think with plenty of PB blaster or WD-40 a left hand drill bit and an easy out you should be able to get it. Good luck, sheared bolts are no fun :(
    84' 325i -> PRO3 #304
    Powered by Manntechnik
    Work in Progress Build Thread
    • drumad
      • Aug 2009
      • 1700
      Look at the other side.
      2008 335i - n54b30
      1991 318i - m52b28
      1994 fzj80 - LAND CRUSHER
      • StereoInstaller1
        GAS
        • 22679
        I broke one off on my car too.
        To make it worse, I screwed up when using the easy outs and broke one of those off too.
        Worse yet was I found out I was drilling between the bolt and the threads...FML.
        What I ended up doing was chopping a small hole in the side of the frame rail, chopping out the "nutsert" looking thing that was the "nut" originally, then welded 2 nuts to a strip of metal and shoving it in, bolting up the CAB and welding the hole shut.
        Pulled up nice and tight, aligned perfectly, drove great. Sounds like a win, right?
        It sucks. When I wrecked that car last spring, a small fenderbender trashed my car. It is headed to the crusher. Seriously, if you saw the visible damage, you would laugh...but it is a bitch to get it to drive in a straight line, it is fucked. No damage to the trailing arms or the control arms, but it tries to drive in a circle...the car is trash.
        Good luck, bud. That is a bitch to deal with.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • gtdragon980
          • Jun 2008
          • 1808
          @kevorm giving that a try this weekend, hopefully things go smoothly!
          @drumad is it not closed off on the other side? Or am i ruhtard and didn't realize I can access the holes from the top...wow I really need to work on my wording lol
          @luke sounds like I'm in for a world of trouble huh? Hopefully I can just drill the damn thing out and rethread it. I know I won't have it come out a easy a using an extractor!
          2002 325i - DD
          • gtdragon980
            • Jun 2008
            • 1808
            Okay now I feel stupid for not understanding what you meant drumad, lol I just didn't want to take the other side apart and fuck that up aswell since everything is back together on it!
            2002 325i - DD
            • cormier
              • 380
              Nothing to grab onto with pliers or anything?
              • Northern
                I like cupcakes & sh!tboxes
                • 5262
                Use a proper sized easy out the way it is supposed to be used on the bolt you sheared off and you shouldn't have any problem getting it out.
                Originally posted by priapism
                Originally posted by shameson
                • drumad
                  • Aug 2009
                  • 1700
                  Haha no. I was hoping I understood what you meant as well.
                  I'm pretty sure it's a thru hole so you can just finger it and check the depth.
                  2008 335i - n54b30
                  1991 318i - m52b28
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    Well, I will take a look at it this weekend and see what I can do about it. I can't really remember if there is much of the bolt sticking out still or not. We'll see what happens!
                    2002 325i - DD
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Weld a nut to the broken off bolt portion?
                      Image for comprehension...
                      The heat from welding helps break the bolt threads loose as well.
                      • etxxz
                        • Feb 2006
                        • 2085
                        Screw Extractor kits are really good. Since its the head that broke off there shouldn't be much torque holding the bolt in place.
                        Drill hole,
                        Insert Extractor (reverse threaded)
                        Twist in by hand! untill it locks and extract screw.
                        Drill with patience don't wobble around and wear safety glasses. Lube your bit often too. This should be a 15-30min job, 80% of it drilling with patience.
                        wow that's a brillian idea. will use in future.
                        No more e30s for me.
                        88 black BMW OBDII 332is dedicated track [sold]
                        88 BMW OBDII bronzit 332is [RIP 03/08]
                        91 BMW 325i [sold]
                        86 Corolla 'Ae86' HB 20v trd [sold]
                        http://youtube.com/watch?v=pTj7Hn9v5Rs
                        • gtdragon980
                          • Jun 2008
                          • 1808
                          FUCK! Well, apparently I suck or I did something wrong, but I broke the tip of the extractor into the bolt!! The bolt is sticking out maybe 1-2mm but it is not enough for some vise-grips to twist out. It's really stuck in there! I would do what you said Farbin, but I need to find someone who can weld it on for me. No access to such equipment for me to do it. I'm going to see if I can find a service to weld it on for me.
                          2002 325i - DD
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            You twisted too hard.
                            • gtdragon980
                              • Jun 2008
                              • 1808
                              ^figured. I put the setting on the drill to high torque and slowly turned it and snap, the thing broke! This thing is really kicking my ass right now.
                              2002 325i - DD
