need to trim /cut frt brake backing plates...
  • JRKOUPE
    • Dec 2004
    • 3159
    for a BBK install.
    What did you use to do the cutting?..
    tia
    jrk
    • 37833
    How big is your BBK? I still have the stock backing plates behind my UUC BBK, just needed a slight tweak.
    Grover Beach, California
    BimmerHeads.com
    • JRKOUPE
      • Dec 2004
      • 3159
      your UUC BBK
      Hey...
      I have the Massive STREET kit...280 mm rotor.....probably very similiar to the UUC?
      I was just thinking Id remove the backing plate. The car is only on street to drive to tracks. ........ I know most spec e30 racers remove the plates. I figger itll lower brake temps removed. I run an s50.
      Best
      Joel
      what size is your rotor?....how did u tweak the bp?
        • 37833
        The UUC kit is 298mm. I just did some tapping with a hammer to clearance the backing plate. :)
        It won't hurt to remove it though. You'll need to pull the hub to remove it in one piece, otherwise you'll need to cut it in half.
        BimmerHeads.com
        • SkinnyVT
          • Nov 2008
          • 391
          just remove the whole damn thing or options for cutting: grinder with cutoff wheel, dremel with cutoff wheel, sheet metal shears, plasma cutter, your teeth, etc.
          '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
            • 34839
            I'd just remove it, as well.
            • dude8383
              • Jan 2005
              • 10387
              Joel,
              I trimmed mine with some metal snips and then cleaned it up with a dremel. Not much to remove as well. Lastly, I sprayed everything with rustoleum.
