MC for brake booster delete question
  • Fernflex
    • 264
    Hi,
    In my E30 Im using the Rx7 calipers in the front stock calipers in the rear without abs system and Im using the E30 318i M10 master cylinder. Realoem.com information says the following:
    "Brake master cylinder 19,05/20,64MM part # 34311156273"
    The guy from Massive says with this mc the pedal would be extremely hard but I dont know what mc should I use in my case.
    thanks
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
  • Fernflex
    • 264
    bump
    Please Rate Me:
    ________________
    __________________
    • Exodus_2pt0
      • 5943
      I too would like to know. Should be doing a v-8 swap soon and I have decided it will just convert to manual brakes. Something about a remote-mount system doesn't sit right with me.
      No E30 Club
      • TobyB
        • 5297
        What's the hydraulic area of the Mazda calipers?
        The 20mm master's a good starting place for stock E30 calipers...
        ...but that's for people who like a hard pedal and grippy pads.
        t
        • Fernflex
          • 264
          t
          They told me is the same as stock.
          Do you have a part number?
          Please Rate Me:
          ________________
          __________________
          • Toadleg
            • May 2011
            • 209
            This doesnt answer your question but on e30v8.com they move the mounting point to the brake pedal about an inch to help give you extra leverage on a hard brake pedal.
            • E30RedtopSR
              • 202
              Originally posted by Fernflex
              Hi,
              thanks
              Thats a stepped master, for rear drum brake vehicle. Lee is right, even with stock calipers and rear disc conversion its stupid hard and reeeeeealy weak.
